To activate your account, please contact us by email: automechanic.net@gmail.com (October 17, 2018)
Thread Rating:
  • 1 Vote(s) - 4 Average
  • 1
  • 2
  • 3
  • 4
  • 5
Firmware files for VAG + TPI
#1
Description: Firmware files for VAG: Audi, Volkswagen, Skoda, SEAT for software: ODIS and VCP (Vag Can Pro).
 Before the firmware it is strongly recommended to check with TPI.
Duplicate files from old databases are replaced with identical ones from the new ones (ie in the release date,
not the weight of the file).
Year of manufacture: 2018
Version: 18.04 (19,899 files)
Developer: VAG encoding on D2
Language: English + Russian
Tabletka: not required
Format: data array
TPI - Technical Problem Information from auto concern VAG (Audi, Volkswagen, Skoda, SEAT)
If someone does not know, it is in these official summaries that information is provided on the shoals known to the manufacturer and how to eliminate them. Including there is information about the current software versions for specific block models.
In order not to mess with updating the software of the unit, it is recommended to check with TPI.
The main number of entries in Russian, English (UK), German and Czech, and also in Spanish for SEAT.
Version: 18.03-1 (81,107 summaries)
Language: Multilingual (Russian is present)
Format: disk image (ISO)
REP +Thanks please
Jumpyellow
vag-dataflash-18.04.rar
File Type .rar download
Hits 7
Size 337.5 KB
vag-tpi-18.03-1.rar
Hits 11
Size 14.47 KB
JPRO 2024 + KG
Reply
#2
Hi,
Here is some information how to use TPI. Found on google.
TPI – Technical Problem Information from automotive concern VAG (Audi, Volkswagen, Skoda, SEAT)
If someone does not know, it is in these official summaries that information is provided on the problems known to the manufacturer and how to eliminate them. Including information about the current software versions for specific block models. In order not to mess up with updating the software of the unit, it is recommended to check with TPI.
The main amount of information is in Russian, English (UK), German and Czech, and also in Spanish for SEAT.
Method of work:
1. Extract the required archive to disk
2. Go to the src folder
3. Call the file manager who can search in FILES! for example Total Commander
4. We say to find all the files * .htm with the text we are interested in, for example, the letters of the engine: BSE (and put the dummy Unicode)
5. After the list is displayed, we say “files to the panel”, we call them in the browser in turn and read about the known problems with the car (TPI) and the ways to solve them … After reading the necessary document, you can go to the folder where the required you htm – there often is also a pdf with more detailed instructions.
And a qwlink to video:
https://www.youtube.com/watch?v=ksjZknwy5m8
Hope it helps.
Reply
Forum Jump:
Users browsing this thread: 2 Guest(s)
