With this SOFTWARE you will be able to generate an FDOK/VeDoc code to access special DOS parameters for Mercedes truck programming. With this utility you will be able to disable the AdBlue system of Mercedes-Benz trucks.
Supported codes for calculation:
• XT (changing of NOx torque)
* XN (erase and disable relevant environmental codes and SCR systems )
If I helped you, you can donate to support the forum
This unfortunately works with the program until 2013. There is already a newer calculator, but with reference to hardware. And there are program patches, then the calculator is not needed at all. But thanks for sharing what you have.
