Here Cummins Inpower Incal 2018
rep +Thanks =
WebIncal(PGA) Release :v15.22
Release Date : January 03, 2018
Summary :
Cummins Power Generation has released the following new calibrations and feature Files for January 03, 2018
New Calibrations
124-PS0600
New Features
61-PCC3300
63-PCC2300
71-PCC1302
98-PCC2300V2
Detailed Description:
Cummins Power Generation has released the following new calibrations for the January 03, 2018
New Features for 61-PCC3300
PART#,REVDATE,DESCRIPTION
A056N430.fdl,,CODE-DES FEATURE COMMERCIAL COMMON (3 phase 50 Hz Standby/Prime (175/160) KVA Rating)
0326-7198.fdl,,CODE-DES FEATURE COMMERCIAL COMMON (200/176 KVA Standby (180/160 KVA Prime) (60Hz/50Hz) 1P)
A052N991.fdl,,CODE-DES FEATURE COMMERCIAL COMMON (250/287.5 Standby (225/261 Prime) (50Hz/60Hz) KVA Rating)
A057C782.fdl,,CODE-DES FEATURE COMMERCIAL COMMON (T4F 70kW 600V with Manual Breakers)
A058U539.fdl,,CODE-DES FEATURE COMMERCIAL COMMON (Voltage Range 3300V 3Phase)
A058U544.fdl,,CODE-DES FEATURE COMMERCIAL COMMON (Voltage Range 12470V 3Phase)
A058U547.fdl,,CODE-DES FEATURE COMMERCIAL COMMON (Voltage Range 13800V 3Phase)
A058U542.fdl,,CODE-DES FEATURE COMMERCIAL COMMON (Voltage Range 10500V 3Phase)
A058U543.fdl,,CODE-DES FEATURE COMMERCIAL COMMON (Voltage Range 11000V 3Phase)
A058U546.fdl,,CODE-DES FEATURE COMMERCIAL COMMON (Voltage Range 13200V 3Phase)
A058U540.fdl,,CODE-DES FEATURE COMMERCIAL COMMON (Voltage Range 4160V 3Phase)
New Features for 63-PCC2300
New Features for 71-PCC1302
A058Z595.fdl,,CODE-DES FEATURE COMMERCIAL COMMON (Gain values feature for C28D5 (1 phase) )
A058Z598.fdl,,CODE-DES FEATURE COMMERCIAL COMMON (Gain values feature of AVR for C20D6 (1 phase) )
A058Z599.fdl,,CODE-DES FEATURE COMMERCIAL COMMON (Gain values feature of Governor for C20D6 (1 phase) )
A058Z594.fdl,,CODE-DES FEATURE COMMERCIAL COMMON (Gain values feature for C28D5 and C20D6 (3 phase) )
New Features for 98-PCC2300V2
New Calibrations for 124-PS0600
A056R605,,CODE-DES CONTROLLER PS0600 (PS0600 CALIBRATION)
rep +Thanks =
![qwlink qwlink](http://auto-mechanic.net/images/smilies/qwlink.gif)
Summary :
New Calibrations
124-PS0600
New Features
61-PCC3300
63-PCC2300
71-PCC1302
98-PCC2300V2
![Cheer2 Cheer2](http://auto-mechanic.net/images/smilies/cheer2.gif)
DDDL 8.15 level 10
Xentry Advanced KeyGen 1.1 long
TEBS-E V6.01
ECUTools v1.59
Cat et2021A +FPKG
JCB Agco SISU Power WinEEM4 – JCB Service Tool 2.8.0
TEBS-E V6.01
ECUTools v1.59
Cat et2021A +FPKG
