04-15-2018, 04:21 AM
Carista OBD2 3.6.4 full
Description: Carista OBD2 See ALL blocks, errors on them, reset errors. Can set something, encode.
The program significantly increased the number of readable blocks by the engine ECU the program allows you to read and erase the errors of the ABS.AIR BAG blocks and NOT ONLY.
Requires Android: 4.0 and up
Cat Flash Files 40Gb
JPRO 2019v2 + KG
