Bosch CompacSoft [plus] FSA 7xx FSA 050 2015/1
is used in universal diagnostic complexes Bosch FSA 720, 740, 750, 760, 050. the FSA intended to diagnose engines and electronic systems, and also includes updated details on the connection and verification algorithms , the base reference measured values .. The program allows you to check the sensors and connections, batteries for measuring the leakage current, the passage of the CAN bus signal. Program Bosch FSA 7xx can be integrated with software ESI [tronic], but to integrate the need to match the version of programs.
When the diagnosis you choose your car model and get the set parameters specific to them. The program has a help system, which you will find general information on connecting mototestera description on the implementation of each of the test instructions. Using the reference section, you can see on the videos available that show all the possibilities of using mototesterov Bosch FSA. The new version of the program Bosch CompactSoft [plus] FSA 7xx FSA 050 2015/1 expanded list of cars.
Rep +Thanks =
Rep +Thanks =
Calterm 4 v4.7 + Keymaker
Scania SDP3 2.41 + KEYGEN
