03-12-2018, 08:03 AM
Cartool 3.6 Full
Used to repair airbags (delete collision data), create new dump files for airbags if you lost the original. Disabling IMMO and preparing IMMO dumps for snapping, decoding radio, repair manual for VP Pomp. The software can calculate the pin code for BSI and ECU.
In this software there are more than 3500 algorithms. The program works with BIN files, so you can use any memory programmer.
Installation:
Install the program, then extract the license files from the archive to the root of the installed program.
If swearing on the path to the photo, just copy the foto folder to the root of the C:
Installation:
Bendix ACom Pro
Cat et2020A +Password Factory Keygen
