To activate your account, please contact us by email: automechanic.net@gmail.com (October 17, 2018)
Thread Rating:
  • 2 Vote(s) - 1.5 Average
  • 1
  • 2
  • 3
  • 4
  • 5
ECUSafe 2.0
#1
Car
ECUSafe 2.0
Is a program that protects program in ECU against being read with all OBD flashers or programmers including:
- MPPS
- CMDflash
- Optican
- Byteshooter
- Alientech KESS, KESS2
- Galetto
- KWP2000
- Dimsport Genius
- Heron Katana Flash
- all other OBD K-line or CAN flashers - original and clones.
You can write new program with any tool you want. Manufacturer’s service workshop can do all diagnosis and even write upgraded version of program into ECU. But nobody can read your work via OBD or CAN.
Removing of FAP / DPF is easy ! All you need is to read original file from car and process it with proper ES module, designed to find and remove all important DPF structures automatically, without your attendance.
File can be then directly written in ECU, or it can be tuned by you and then - written into car. DPF can be removed from car, sensors left unplugged (no sensors at all) or left in the exhaust. It does not matter.
No more regeneration, no more black smoke behind. No more DPF check light or lamps on the dashboard. Add DPF removal offer to your workshop capabilities !
Rep+Thanks= Key
ECUSafe 2.0.rar
File Type .rar download
Hits 11
Size 105 bytes
Iveco Easy 18.1 unlock
JPRO 2025v2
Perkins EST 2025A
Agricultural DAMOS
TRUCK DAMOS
DAF AND PACCAR DAMOS
Scania SDP3 2.67 unlock
SCANİA EMD1 SCR,DPF,EGR OFF FİLES
Reply
#2
Pass please
Reply
Forum Jump:
Users browsing this thread:
